Instrument cluster wood removal?
The Instrument Pack veneer is secured with four Trim Clips:
![Instrument cluster wood removal?-x308-veneer.jpg](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/27441d1480967150t-instrument-cluster-wood-removal-x308-veneer.jpg)
A view of a Trim Clip is circled in red.
The veneer is on a metal backing so it's stronger than you may think but can still easily be scratched.
Check this video on removing the centre veneer on an XK8. The method is the same and it shows the back of the panel and the Clips. Click on the asterisk to run it:
Be careful - the Clips are spring steel and sharp!
The following 2 users liked this post by GGG:
Platinum XJR (11-13-2013),
wrd0225 (10-15-2013)
rsa760041
23
09-25-2015 01:33 PM
