Intake removal and unknown gasket
Hi everybody.
My 2003 XJ8 has a small coolant leak so I decided to remove intake manifold and replace coolant hoses, both knock sensors, breather hose and vacuum line from throttle body to vacuum boost (brake pedal is a little bit stiff, I think there is small vacuum leak at the point where pipe goes to throttle body)
Already got all these parts along with all the gaskets on the way except one - between metal piece below a throttle body and and an intake manifold
Hense two questions:
-how can i find that gasket
-any suggestions what else can I replace as a preventive maintenance since intake will be removed?
pic is from local junkyard, gasket suppose to be between metal part and removed intake (I removed intake from one of the car as a training practice)
Anton Tkabladze (08-15-2022)
vincent661983 (08-15-2022)
slmskrs
07-25-2014 12:48 AM
