Intercooler pump wiring question
If I understood correctly. You have a flying leads. If so you have to either find a correct connector to the car side of the loom. Or remove oe connector and solder wires to the loom. I might do the same thing by replacing the oe connector alltogether with common universal 2 pin connector pair. Let say amp junior power timer for example. Same type of connector that is at the fuel injectors and rear lights.
The following 2 users liked this post by Z07Brandon:
Addicted2boost (08-29-2023),
vincent661983 (08-29-2023)
Z07Brandon (09-09-2023)
Just an FYI, the engine coolant expansion tank would technically be the place to add coolant for the intercooler. You could also add coolant in that Allen plug hole. I would suggest something else but, if by some chance you break that plastic bleeder pipe off the intercooler radiator, then you’ll hold me responsible for suggesting it so I can’t recommend that. Remove the Allen plug and add coolant to the expansion tank and the Allen plug area until you think it can’t take anymore. Once that’s done, put the expansion tank cap back on, squeeze a main radiator hose until air can come out of the Allen plug bleed hole. After air is out, install the Allen plug then drive it up to full operating temperature (95*C) and *while driving* get it up to redline at least once if not twice. Let it cool off overnight and the next day *before starting* check your expansion tank for proper coolant lever.
leapers
06-03-2014 06:33 AM
