interesting questions !!!!
i have a few questions
key-fob re-programmed to car , but car just gives a beep when i press ANY button , also when i lock car manually .
just searched and fouind out the ignition should have a gate ... mine doesnt so thats the 1st port of call tommorrow .
anything else i should look at ??
i noticed i get a warning if i have the trunk or a door open , but not the bonnet . this lead me to investigate and i noticed there isnt a light in there ... is this normal or is it hidden somewhere ?? (if there is one it isnt working)
i also noticed the ground strap to the bonnet/hood is broken . is it urgent that i fix it ?? i dont see what problems it could cause .
twice this week it has let me down .. 1st time it cranked instantly when the jumper-leads where connected . today i just left it at work and will fix it tommorrow .
everything works , just nothing but the ussual "click" when i go to crank .
will clean all battery connections etc. tommorrow .
annoying as the temps have been below zero and the car has been faultless , as soon as the ice thawed the battery started playing-up !!
a quick squirt of wd40 type oil in the lock , and a few quick wiggles of the key made the gate pop
FIXED !!!
i
battery ok (apart from being flat)
charging system ok .
guess i flattened it again
1st time it happened i put it down to me , second time had me worried .
I too don't get a warning for the bonnet being open. I also don't beleive there is a light in the bay to light up the enigine, which I think is unusual for a Jaguar. I don't get a warning for low washer fluid either which I suspect is a loose cable at the washer bottle. Hope all goes well with your battery issue. S.
Scott B
10-24-2015 01:29 PM
