Interior trunk release button backlight
It does pop out, you can reach it easier by removing the coin tray and pushing it from behind. Be aware that the interior temperature sensor is attached to this by a rubber tube which can be troublesome to refit, and the plug(s) attached to the switch have very little travel so you're best removing them via the coin tray hole. The coin tray is held in by a single Phillips screw. Use the opportunity to clean the temperature sensor too, it looks like a MAF sensor.
The bulb is the same as in all the other switches.
ericjansen (11-04-2017)
Of course you should have reacted an hour earlier, but I forgive you
![Icon Bump1](https://www.jaguarforums.com/forum/images/smilies/icon_bump1.gif)
Seriously, thanks, nice little project for tomorrow's rainy Sunday.
EDIT: The removal of the coin tray did the trick, and one can actually just slide the button part out, that leaves the interior temp sensor in place (which is working fine for me).
Muchas Gracias Again!
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/p_20171104_182808_d094c81c86d2a3d0019d1385bb2cd5fae0a7f93f.jpg)
smith356 (11-06-2017)
Missed that !
dneider (12-04-2017)
Man you truly know something's over engineered when tasks as trivial as changing vanity bulbs takes vast research lol. I had to go through 3 vintage Jag parts' dealers to confirm what bulbs the driver's side switch pack took. Finally got to the bottom of it though.
X308 never a dull task lol !
