Intermittant Alarm lockout
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
1998 XJ8 Vanden Plas: When turning the car off the stereo speakers will pop and the indicator by the shifter begins to blink. Occasionally the alarm will sound.
Using the key in the door/ ignition and locking/ unlocking with the fob produces no results. To clear the battery must be disconnected for several minutes.
When it happens pushing the key in to the barrel further produces beeping and blinking dash lights. Is there a fix, is this a transponder coil issue or are there other switches on the assembly? Please help.
Welcome to the forum Jessica,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
XKR_100
12-12-2019 02:38 AM
gsinoc3
03-23-2012 01:01 PM
