Intermittent ECU Gearbox Fuse along with trac/stability control fail
I've got a 1998 XJ8-L that has a few problems. Not exactly sure if they're related to one another but want/need to get them sorted out.
First problem I have is the ECU gearbox fuse tends to blow almost all the time. Sometimes, it's one after another and there are times where it'll go a few days without blowing a fuse. Once that fuse blows the car goes into limp mode and does not want to shift.
Another problem I'm having with it is, both the traction control and stability control failure lights are on along with the ABS warning light.
I'm not exactly sure if all those problems are related to one another and it's a common issue or I've ran into separate issues.
Hopefully someone here has an answer for me. Thank you.
abonano
25
09-25-2015 10:43 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
