intermittent no start - Fixed - FAQ
Old 06-17-2011, 11:18 PM
QuadManiac's Avatar
Originally Posted by Gus
Please define exciter ring.
Sounds like the RFID receiver antenna (for the 'smart' key) on the steering column. There's one reference to it in the wiring diagram, but no specifics.
Old 06-18-2011, 07:07 AM
bigcat01's Avatar
Default exciter ring
Correct mechanic terminology is key exciter coil
Part number lja2668ab also listed coil-key transponder
they also had to reprogram all keys
Old 06-18-2011, 11:59 AM
QuadManiac's Avatar
Interesting that ALL of the Jag wiring diagrams across the years 98-02 for XJ and XK have one and only one reference to 'reader/exciter' in the body of text with a referral to schematic figure 13.3, for instance, but in every year/model wiring diagram, that referenced figure is not included. (for example, look at page 8 of the 2000 XJ wiring diagram - exciter refers to figures 13.3 and 13.4 - NEITHER of which are in the document)
The key transponder module is shown in all docs, but without any cross reference to the exciter coil... are they one and the same? The part number that BigCat provided does refer to 'Coil/key transponder' so it must be at least part of the key reading RFID system - it's just not shown in the schematic diagrams, which is frustrating. Also, the cost is around $20, which, to me, implies that it's not the module itself, but that it's just the coil that connects to the module.
I find this rather unusual - the first time I've found any of the Jag wiring diagram information to be lacking or confusing.
Old 06-18-2011, 07:13 PM
bigcat01's Avatar
Default no crank
I found this unusual also and so did the technicians at the Jag dealership. The codes all pointed to the bpm and when that didn't work they were left scratching their heads. If one of them didn't offer to swap parts, my car would have just been a rather large paperweight.
Old 06-19-2011, 10:12 PM
Viapa's Avatar
Originally Posted by bigcat01
My intermittent no start came back about a year later. I bit the bullet and took it to a jaguar dealer in charleston, sc. After going through the whole electrical system they said it was a bpm issue. They wanted say $800 for a new bpm with no guarantees. If I said go ahead with the new bpm and it doesn't work, the bpm is mine. I found a used bpm with my exact vcat label from a local mechanic and brought it down, didn't work. Well, to make a long story short they didn't know what the problem was. After giving them a nasty attitude, one of the mechanics had the exact same car and was willing to swap parts until they found the problem. It was a faulty exciter ring, about a thirty dollar part. After all said an done it cost me about $400. I hope this helps. Driving like a charm for 6 months and still get 26 mpg on the hwy with ac running. 22 mpg around town. Hope this helps. If you had my exact problems $30 part could be worth a try.
Do you have copy of repair from the dealer that can fax for me to show the TECH? Matter of fact can you post a copy for me print on the Forum
Old 06-20-2011, 03:42 PM
bigcat01's Avatar
Default Notes
Inspected and found engine would not spin- jumped starter relay and engine spins over-checked for signal to relay- no signal present- performed immobilization relean and key programming condition still present- checked resistance of wiring from bcm to starter relay-ok- monitored security status and found bcm not changing- ecm and bcm get the same signal on the same wire from the key transponder module- ecm was changing- suspected faulty bcm- replaced bcm with part from client- condition still present- swapped key exciter coil from known good vehicle and engine started- replaced key exciter coil= programmed key to vehicle- vehicle starts and runs
This is all i have from dealership.
The following 2 users liked this post by bigcat01:
JimC64 (06-20-2011), Viapa (06-20-2011)
Old 06-20-2011, 08:12 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Well, there it is- another exciter ring being the root cause of no start.
  #28
Old 06-20-2011, 08:31 PM
Received 9,011 Likes on 4,114 Posts
Thanks again for the follow through bigcat, it could be really helpful to others
I'm gonna mark this thread *fixed - FAQ* and one of the mods will add it to the FAQ section
Old 06-20-2011, 09:15 PM
Viapa's Avatar
Default Thanks!
Well today they (dealer) had a hard time starting the car so they replaced the battery (as usual) BUT to see if that might be the problem. They are keeping the car overnight again to see if it starts. Then I guess they're move through there set of test on the electrical system. I am going to use this info that you gave me and show this to my Service Advisor so tomorrow they'll have a real starting point on diagnosing this. Thanks so much for info.
  #30
Old 06-20-2011, 09:21 PM
Gus's Avatar
Gus
Gus is offline
Received 2,215 Likes on 1,703 Posts
Kudos to you! On the road again!
JarodL
03-07-2024 01:39 AM
99xk8guy
06-05-2023 06:28 AM
Jpav27
07-31-2022 06:43 AM
Shawn Svacha
11-04-2019 02:47 PM
XJsc-guy
09-02-2015 11:43 AM
Quick Reply: intermittent no start - Fixed - FAQ
