Intermittent non-cranking issue
'02 XJR - Brought the 'ole girl out from her Winter slumber and now after 10-15 successful starts I'm having intermittent non-cranking issues.
Brand new battery, no codes, but occasionally (and becoming more frequent) I'll turn the key to the crank position, and nothing (post successful system check). If I turn the key all the way back and try again, sometimes it works and sometimes it takes 2-3 attempts.
Ignition switch maybe? Any suggestions on what to troubleshoot first?
**EDIT: I've found some good info in the following thread, but it points to a lot of possibilities.
starter relay
ignition key replacement/re-program
exciter ring
trans interlock
https://www.jaguarforums.com/forum/x...-problem-9439/
Thanks,
Dan
starter relay
exciter ring
trans interlock
Thanks,
Dan
Received 1,795 Likes
Don B (04-27-2018)
Tman
08-23-2015 06:56 AM
