It's wheel bearings... not tires!
I recently posted an inquiry about tire options for the XJR because I seemed to have gotten some bum tires. I spent a little over $300 per tire for Michelin Pilots earlier this week and thought I was extremely disappointed with the performance of these tires I had spent quite a bit of time researching. "They" transferred road vibration, like driving on a very fine washboard- especially above 33 mph. Sooo, I decided I needed differend tires and I shouldtrythe Bridgestone Potenza Pole Positon tires - which must be better....
Well...... I went to Tire Kingdom early this morning (this time in Gainesville, instead of my long-time shop in St. Pete which installed the Michelins) and the techsaid that my front wheel bearings were shot. WHAT??! Obviously, this couldnt be since mycar has only just turned 53K miles..... Oh, yeah? I went to a localmechanic who had worked forever at a Jag dealer in W. Palm and he said thatthis was a common thing. The car went up on the lift, spun the wheel and you could actually FEEL the vibration in the lower control arm from just spinning the front wheel by hand! Imagine that at 35mph? So, the Tire Kingdom tech was right! As it turns out, I dont have a tire issue, I have a wheel bearing issue. Unfortunately, it seems you can't just replace (or even repack) the wheel bearings like you can on my '60 VW Kabriolett. You have to get the wholefront wheel hub assembly. Thank goodness I have the Jaguar Extra Mile Exclusionary policy. I took the car to the dealer in St. Pete and it will be covered. My rear diff is also leaking a little, so they will do that, too. My J.E.M. warranty is up in late Sept and I think this underscores my decision to renew my Jag warrantywhen it's due to expire. The front wheel hub ***'y is only $495 PER wheel!! Who knows what the differential seal (or whatever it needs) would cost me. The dealership will also run a complete diagnostic on the car (including a compression and leakdown test) while it's there. Since my deductible is $200 per visit (as opposed to per ITEM) I figured this would be best. May as well fix anything/everyting all at the same time!
BTW, did I mention I LOVE this car??
RE: It's wheel bearings... not tires!
ORIGINAL: Envy337
Are you paying for the compression and leakdown test?
A note on the bearings:
You can replace just wheel bearings. Most guys are not skilled enough to press them in to the hub so they opt to replace
the whole hub assemby.
You are better off that way anyway, at least you know it was pressed right from the factory.
Allways request to have an experienced tech work on your car.
Guest
Posts: n/a
Thw wheel bearings on the Jag are just as easy to replace as any other car and any mechanic will have the proper tools to press the bearing in. What a regular shop might not have is the special tool to take the ABS ring off. I bought one but you can tap it loose with a brass punch. The front wheel bearings for the x308 are regular ford bearings, same ones as in a ford tempo. I even checked the part number etched into the original bearing that came out, it's the same thing. I've got to do the right front on my R soon, I did the left about two years ago. The bearing is only about $40.
I had to replace both front wheel bearings (1998 xjr) recently - the wheel/tire guy was fairly skilled, and manged to press them in without replacing the hub assembly, but it wasn't cheap (spent about $700 total, $350 each). I guess it took him a while to figure out how to do it properly.
Guest
Posts: n/a
Just did this job my self, Not to hard to do just basic tools except the abs ring.I'm sure you get it of fwith a brass drift and hammerbut what about putting it on? Its supposed to be around 130 lbs? Well what I used and worked perfect was a 4x4 4 prong axel nut socket. Much cheaper than the real thing (25 to 35 bucks). Sorry if that puts any vendors out of biz but hundreds for a socket. I did the whole job both sides for around 150.00
Guest
Posts: n/a
Thanks for the complements on the photo.
I just did the right front wheel bearing in my R last night. It took about 2 hours of heat and hammering to get the ABS nut off. The last few I did weren’t nearly that hard including the left side on the same car. If it wasn’t for that I could have had this job done in less than two hours. It really is pretty simple.
1964Daimler
09-09-2015 11:28 AM
