I've changed these 15 things in the last 2 months, I now have 650 HP+ on tap :)
#61
Nice stolen picture RPi Exhaust (F10 M5) Dyno results are in. OH YEA!
You're really being silly now...
I'm glad someone got it.
I am being silly, I did think it would be funny to send people on a wild goose chase by giving an example of exactly what I was talking about.
All of my posts say exactly where I am with the Nitrous, which is that it is not yet functional on my car, and that I think I am at approx 470-475 HP on the motor.
This is exactly why I am suggesting VIDEO proof as ANYONE can post a fake dyno.
I left a hint in my edit explanation that the post was bogus as well as the names of the photos.
When I make my runs they will be on video, and when I do a dyno, it will be posted on video.
But again, I am not selling anything
#64
You'll get far better results with a full intake system and for much less money too.
#65
I guess you have stock 4.0 head gaskets? Using that amount of NOS with already higher than stock boost, it's very, very close to burn at least your gaskets if not blow up whole engine even you have NOS controller. 4.0 pistons are not forged ones. Be careful with amount of NOS in stock internal engine. Maybe 150hp shot is ok, but maybe not.
#66
Here is one what? What have you prepared?
In other news, We now have a report of another 4.0 XJR running 450 RWHP with NOS. This is good. 450 / .83 = 542 Flywheel HP
So, it has been suggested that similar 4.0s have/ are running 450 RWHP = 542 Flywheel HP, so is there any reason to assume mine could not handle the same level?
If you read my posts, it is very clearly stated that the "on tap" figure is clearly explained as theoretical, and that my goal is to be able to run an 11.99, and that might not require more than a +70 or 100 RWHP shot.
Would 542 flywheel HP enable me to get to an 11.99? Opinions?
So my now calculated 476 (from 10.5 sec 0-100mph run below) subtracted from the 542 flywheel hp figure above is a difference of 66 HP. So I if I only run a +70 rwhp jet / .83= +84 flywheel hp jet....
476+84= 560 flywheel hp.
Steve, would it be fair to say you were running approx 550-560 flywheel hp when you ran your 11.92? If so, theoretically I might be able to match that with a +70 jet.
#67
Video showing 17 psi of boost at 5000 rpm! Yeah Baby! 65 degrees out.
I wish my phone would have started recording earlier, with 140 lbs less in the car it is faster than the last run. This run was faster than my last 10.8 sec 0-100 mph run. See how fast it spools up 1st and 2nd gear If you blink, you will miss first gear.
The 0-100 mph @ 4160 lbs calculates the flywheel HP at 476 for this run.
#68
WaterDragon (10-01-2013)
#71
Wow! that is A LOT of boost. Are you saying 22-23 psi boost, as in the fuel pressure increases matched boost, or did I read your post wrong?
What happened? Did you lift a head a little and blow a head gasket?
I was thinking at some point to switch to stronger and thicker head gaskets to lower compression a little and swap to ARP head studs.
#72
1 degree over freezing, that is some very cold, very very dense air.
At least some rear wheel spin when kickdown at 70MPH. Dry road.
#74
#75
Season is almost over here, 38F right now. There are some ideas what happened, but I will update when sure about the details.
#76
the one i preparared earlier
I have heaps of trouble up loading pics on this site
around 6,000RPM 4th gear 1-2 seconds detonation - Hood jumped up a 1/2"
1 and 2 cyls right bank
you can see detonation damage on forward cyl - top ring exposed
head gasket destroyed and a major flame-out through cyl wall.
Big boost and low fuel pressure is probably the major cause.
The following 2 users liked this post by dc4prez:
WaterDragon (10-02-2013),
Whitecatt (10-02-2013)
#77
May I ask a few questions? First, which KB twin screw kit were you using? Secondly, what instructions were you given to prepare the fuel delivery system to deliver the additional demands of fuel? And finally, what would you recommend to do if you had to do it over again?
Thank you for sharing your information.
Chuck
#78
off topic
I'm looking in to Kenne Bell boosta pump - then mine heads to Dyno,
I don't like how they activate them, they use a boost sensor , I'm looking at TPS voltages -- I'll PM that too you when I have more info.
#79
What tires are you using? When I had P Zeros on my car in the winter the tarc light would come on when accelerating on the highway. They were awful in the cold weather.[/QUOTE]
GoodYear Eagle F1, rear ones almost bald. Time you buy new set. I just bought these kind of wheels in mint condition:
#80
I really hope nothing too serious. Maybe just clogged breather system with lot of blue smoke which went even worse when added more oil before the race, but better to make cylinder pressure test as well as check cylinder walls with endoscope. I am ready for any bad news... Even with big engine problems car run 12.5/110.
