I've never had a Jag but I want an XJR
Old 07-15-2007 | 01:11 PM
93xj6's Avatar
Default RE: I've never had a Jag but I want an XJR
Texas Cars Direct is a great dallas area place for jaguars, alot of people recooment this place, I have heard on several forums.
This is the cheapest XJR they have, but look at the inventory, they have a lot of nice cars.
http://texascarsdirect.com/PublicWeb...l.aspx?id=7814
You should go check them out tho, they have some XJ8s that are fairly new for less then 15,000
Old 07-15-2007 | 06:08 PM
nti06's Avatar
don't ever put sediment filled gas in one of those. an inconvenience for you and a bad day for the gas station.
Old 07-15-2007 | 06:45 PM
93xj6's Avatar
I think anything 200 or newer won't have the nikisil problem, at least that's how it is in XK8's, IDK about Xj8s, but it's the same engine so I would assume.
That;s all I can help you with there, cuz it is the same engine as my dad's car, and we haven't had anyproblem with Jag's V8 engine, it's a good injun.
Old 07-20-2007 | 10:45 PM
FL XJR's Avatar
I, too, have had a 300 SEL 6.3 (1970). That car was a monster! The XJR is much more refined. You dont feel the torque through the transmission as you do with a 6.3. It's more like the 6.9. Mercedes toned down the torque converter in the 6.9 tranny. That's why the 6.3 is actually faster to 60 than the 6.9. Annyhoo, having owned a 6.3 and driven my buddy's euro 6.9, I still LOVEmy XJR. However, $15K or under you may be limited to 1999 or older. If you can get a 2000 or newer, you should go for it - no Nicasil issue. If you get a car with 70K miles or more, change the timing chain tensioners (if they havent already been done.)
Forcedair1
05-14-2023 04:28 PM
allenman85
05-10-2021 04:11 PM
FeralJag
01-11-2016 06:07 PM
XJsc-guy
09-25-2015 12:09 PM
Quick Reply: I've never had a Jag but I want an XJR
