J-gate will not shift out of park
I have a 2000 XJ8 VDP and it is stuck in park. The problem started when I wen to to Drive and I forced it so the housing broke were the Interlock solenoid. I went to the wrecking yard and replaced the J-Gate. After I installed the J-Gate the shift solenoid will not engage to shift out of park. It seems the solenoid is not getting power. If I manually release the shifter to reverse and drive the transmission with shift. I replaced the brake light switch assuming that this would solve the problem but no suck luck. When I start the car the J-Gate will light up in park, reverse and drive. I am getting the following codes: P0790, P1798, C1095, U2500, U1261 SCP and 1948. I would like to add I also purchased a new Battery and I got these codes after the Battery was installed.
I realize that this a a lot of information all at once but the Car will start without a problem, I just cannot get it out of Park and any assistance would be appreciated.
I kinda read the first and last lines of your post but I see that you replaced the broken part and want it working properly.
"I have a 2000 XJ8 VDP and it is stuck in park. The problem started when I wen to to Drive and I forced it so the housing broke were the Interlock solenoid."
"I realize that this a a lot of information all at once but the Car will start without a problem, I just cannot get it out of Park and any assistance would be appreciated."
Figure 5.3 of the Electrical Guide diagrams the circuit for the selector lever 'park lock solenoid'. The signal goes through several modules.
Let the diagnosing begin!!
Gus has all the electrical guides for these old cars (I know because I sent him all the one's I had)
Figure 5.3 is in the 2000 XJ8 electrical diagram and I am sure you can download it in .pdf.
http://jagrepair.com/images/AutoRepa.../jagxj2000.pdf
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1500x854/lh_hilboard_timer_3_s_6c9391a9afdfc113530c17cd33053033444fc0e7.jpg)
grandhaze (10-21-2021)
The following 3 users liked this post by Maverick115:
Rlover
03-30-2016 10:04 PM
