Jag teething issues...
Hello,
I'm new to Jag & the forum and thought I'd post a question. I'm running thru a list of things to take care of on my newly acquired 99 XJR. As delivered it was missing the driver's door cable. I sourced one and installed it and upon reassembling the door panel find my driver's window is the only one functioning (they all worked before). Also strange is that it functions with the rear passenger switch (only). The mirrors don't adjust either (they did before disassembly). The connector is foolproof (no way I can see to assemble backwards) so I can't think of what I might have done wrong here. Am I going crazy? Am I on candid camera? Has anyone else seen odd behavior like this from their cat? I do still have the front passenger panel off the door while I deal with some storage bin issues.
Doug
Doug
Hello,
Doug
Doug
I'd try disconnecting the ground cable (the one that goes to the body), touching the ground cable to the positive post (don't disconnect the positive lead...what you're trying to do is drain the circuits...it won't hurt) to about 30 seconds, reconnect the ground lead, and try again. You may have to reset your radio (hope you have the codes if it's a code-protected unit) and window/sunroof (if you have one) travel, but, I've found that usually corrects any stray bogosity in the car.
Worth a try.
dwgates (05-07-2015)
Funny, I found the battery reset thread after I posted my topic. As I'm in the middle of a (2) fuel pump replacement I'll try holding the negative cable to the positive post ahead of hooking it up again. Funny to see a computer be assigned such menial tasks. Hopefully the tank will be out tomorrow, just have to do the hard part of disconnecting the lines under the car and remove one of the trunk support struts and I think it will come out. hanks for the replies.
Well it turns out I was not crazy, on candid camera, or able to plug my driver's door window connector in backwards (my wife was sure I'd done this...and thinks I'm crazy). Once I got my fuel tank in place I held the negative cable against the positive terminal for 30 seconds and reconnected the battery. Everything works as it should. Now my big issue is to get rid of thee rest of the tinted window residue as it wants to fold the door to glass seals over on themselves. Thanks for the elp and I too will be keeping a 10 mm wrench in the glove box just in case my cat loses her mind again.
VinnyT
69
05-17-2021 09:30 AM
