Jaguar autotilt problems
So, in my XJ8 when I have the steering wheel set to the auto tilt function I have some annoying problems. First, when you pull the key out the wheel tilts back and the seat slides all the way back. but when you put the key back in the wheel comes back down but the seat doesn't slide forward automatically. Also when I have switch set on auto the yellow Airbag light comes on and it doesn't when the auto setting is not on. Is the seat supposed to slide forward again?
Wiring....
....deleted initial comment, didnt read the op fully.
Theres a side airbang in the seat, there's a fault in the wiring under the seat, it's 4 torx bolts, then inspect the connectors and wiring you should find the break and fix it easily, hopefully
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
