"Jaguar" badge
There is a seller on ebay UK with a stock of US Spec Wing emblems Priced at £11. Genuine New JAGUAR BADGE XK XJ XJ12 XJ8 XKR Sovereign | eBay
I've found eBay is a good source for new badges, there are all sorts of sellers with listings. The badges differ in price slightly when buying direct from Jaguar, but the price is justifiable when you consider they are three piece items with a limited market.
Jaguarstyper (12-20-2017)
You can always mod it to look as good as a X300 . Called a direction side repeater Jaguar # LNC4812AB for both left and right . The hole should be the same and the wiring would be easy . Polishing a used lens with a compound makes a big difference . Ensure you have the uprated fuse of 10 amps from 5 as reflected in the Jaguar wiring guide . Can find some at the local junk yard for a couple bucks and try .
https://www.ebay.co.uk/itm/JAGUAR-XJ...-/182948685914
Pushing_Tin
08-09-2011 12:18 AM
hawaiianjag
09-08-2010 03:02 AM
