jaguar emblem
Old 09-12-2013, 12:22 PM
Cesandman's Avatar
Default jaguar emblem
Where can I buy a driver-side front fender emblem for a 2000 XJR Jag?
I need a tire 225/40 ZR 18 95 Y Michelin Pilot Sport A/S. Where is the the best place to get a good deal?
Old 09-12-2013, 12:31 PM
Received 1,231 Likes on 716 Posts
First off Welcome to the forum.
Why not follow the guidelines and introduce yourself over in the New Member area.
Secondly, I would think that the Vendors in our directory will be able to fix you up.
Old 09-12-2013, 01:07 PM
vincent661983's Avatar
why not to covert it to euro-spec side turning signal light ,just my suggestion
Old 09-12-2013, 02:03 PM
Badbenz94's Avatar
Can't you buy it at Jaguar? How about ebay?
Old 09-12-2013, 03:40 PM
Old 09-12-2013, 03:43 PM
dmpsqrd's Avatar
Soo- as long as someone brought up the subject- is the wiring behind the fender behind the front fender emblems for those of us who haven't converted? Source for the turning signals? and- WELCOME!
Old 09-12-2013, 05:58 PM
driver side is per-wired with harness so just a plug and play situation , but you need to find the harness and run the wire from the relay for the passenger side, a few minute job
JAGUAR X300 1995 PAIR OF FRONT WING INDICATOR SIDE MARKER REPEATER LIGHTS | eBay
dmpsqrd (09-13-2013)
Old 09-13-2013, 09:03 AM
dmpsqrd's Avatar
Default repacing fender emblems
Searched- is there a link on the process?? thanks- dan
Old 09-13-2013, 12:04 PM
let me see if I can find a harness I got while I was doing the conversion.hint ,go to ebay UK to find it, those selling the sidemarker ,ask if they also have the harness with it.
I also understand it is the same harness for the car trunk interior light
it is definitively the easiest retro fit I have done on the Jag and it is prettier than the useless emblem and functional
The following 2 users liked this post by vincent661983:
dmpsqrd (09-14-2013), smtguy (09-14-2013)
Old 09-14-2013, 09:46 AM
smtguy's Avatar
Vincent,
I am interested in doing this retrofit. I had these on previous SAABs and Audis, and they really are required defensive equipment for Southern California freeways.
You say the drivers (left) side is plug and play meaning I assume that the harness is already inside the fender and I would just need to plug in connectors to the side marker. The right side needs the harness run to the relay (which relay and where?). I see that you can get the markers from newer XJ6s. Is this the correct harness to use too?
Any information or assistance here is greatly appreciated.
Old 09-14-2013, 09:51 AM
dmpsqrd's Avatar
Vincent- would do this conversion for my 00 XJR in a heartbeat- let me know any info you might have regarding harness and parts- thanks again- d
Old 09-14-2013, 12:07 PM
Platinum XJR's Avatar
I am also interested in swapping out the leaper badges for lights. I pulled the left side leaper and looked inside the fender. Did see a wiring bundle, but did not see any wiring / plug like I was hoping to see in there.
Have not been able to find directions on this.
Stewart
Old 09-14-2013, 12:59 PM
I forgot to mention to the OP.
If you cannot find a new emblem, send me a PM.
I have an extra set.
Stewart
Cesandman (12-18-2013)
Old 09-14-2013, 02:12 PM
folks, I cant find the harness, but it is the same one as for the trunk interior light expect it is clear lenses
again, referred the the following, Both X300 and X308 share the the same sidemarker
I also use the LED light on it
Old 09-14-2013, 02:35 PM
I did the conversion on my XJR, IIRC it's the right one that is pre-wired, the plug is actually attached to the back of the leaper emblem.
I had to order the side marker lamps from England, the trunk lites are the same plastic frame, but they lack the metal clips to hold them in place in the fender.
I have two trunk lights for sale, if anyone wants them, PM me for info.
Vector
Platinum XJR (09-14-2013)
Old 09-14-2013, 03:32 PM
Old 09-15-2013, 08:41 AM
smtguy's Avatar
Vector - what parts do you have for sale to do the side marker conversion? What else would I need to buy?
Thanks,
Old 09-15-2013, 09:40 AM
Thanks,
I had two white trunk lights, but I just sold them.
You need either two side markers with metal clips (I got mine shipped from England, since they don't exist over here) or two trunk lights, if you want white markers, you will have to figure out how to mount the trunk lights in the fenders, they fit the opening, but they don't have metal retention clips like the true, amber side markers have.
You will also need one female plug to attach to the side that is not pre-wired. You have to remove the fender liner and run a line from the turn signal on the front bumper to the side marker. The other side is plug and play easy.
Vector
The following 2 users liked this post by Vector:
dmpsqrd (09-15-2013), smtguy (09-16-2013)
Old 09-15-2013, 05:15 PM
dmpsqrd's Avatar
soo- we are looking for side markers from England? To fit either 308's or 300's? and a wiring harness for the trunk lites? Could't we just splice a wire to the front turn signals?
Old 09-15-2013, 06:35 PM
I said ......"You will also need one female plug to attach to the side that is not pre-wired. You have to remove the fender liner and run a line from the turn signal on the front bumper to the side marker. The other side is plug and play easy."
Vector
Quick Reply: jaguar emblem
