Jaguar XJ8 1999 4.0 Slight water leak!
I seem to have a slight water leak on the hose that goes from the coolant reservoir to the top of the radiator I believe it is the overflow hose. I am not sure if the plastic hose clip is in the right position or if that does not matter ?. But I have tried turning it and depending on which way I turn it. It makes the leak worse. If anyone has a picture of which position this plastic clip should be in it would help ?.
Many Thanks
Mat
Many Thanks
Mat
You're talking about the tiny tube, like 8mm diameter, right? There's an o-ring inside that connector but if you can rotate the connector easily, then you need to carefully inspect where the tube is swedged onto the connector as its too loose, maybe has cracked. On a brand new part, that connector is so tightly fitted to the tube that you can't rotate it, at least not easily, rather would twist the heck out of the tube before the connector would turn.
I replaced mine recently and got it from https://www.motorcarsltd.com/search....keep_https=yes for just $23.00.
At these prices I also replaced the one from the reservoir to the thermostat tower (MNC4582AC) https://www.motorcarsltd.com/search....keep_https=yes
Don B (04-23-2019)
Don't twist it off, it's just push-pull, but you have to "release" the retainer. There is a special tool just for spreading the retainer clip, but you don't really need it. Notice there is a round ring around the perimeter and if you squeeze it on two sides, it spreads and makes an oval, thus the tabs spread far enough to pass by the lip on the radiator or tank nipple and you can pull it off. Sometimes, just squeezing it is enough, but rarely. Usually it needs some "help". So I take two small precision screwdrivers and push under parallel tabs on either side. I just happen to have screwdrivers with shafts just the right size. Some people use a medium sized nail (the kind you hit with a hammer on purpose, not the kind you hit with a hammer by accident). But that's essentially all the special tool is, just a two-pronged fork with tines of a certain size.
Don B (04-23-2019)
Matt, are you looking to replace the hose from the expansion tank to the radiator?
If so it can be sourced here.... https://www.motorcarsltd.com/search....keep_https=yes
Hi Matt, I recently did my hoses, the small diameter ones that run from the header tank, on my Daimler Super Eight. If you don't have the special tool then a pair of thin needle nose pliers will do. When you get to pull the hoses apart check there are no cracks or splits. If there are, you should/need to replace them. Its a waste of time trying to repair them. Also there are 2 small rubber 'O' rings in the male part of the connectors. Replace them as they will be old and compressed and may not seal properly. As you live in the UK, British Parts in Stevenage will have what you need over the counter. Check out their web page and I have found them helpful over the phone too. They do deliver but check their delivery fees. Good luck!
O Ring.
Can you please give me the link to the actual part required on this site ?. I don't know what its called or what I'm looking for.
MNC4583AC
This is the link to the actual part, but as you are in the UK, I think, maybe you can source cheaper locally?
If you feel that the hose is still viable then go to any hose/seal shop in your area with the hose off the car and explain what you require.
I needed a replacement cup seal for my VH40 brake booster and took the sample in and they made one to fit.
For you it should be just an off the shelf item
Don B (04-23-2019)
Jaguar does not sell the O-rings separately, so there is no part number. But it's bound to be a standard metric-dimension O-ring. Any good auto repair shop in your area should stock metric O-rings and be able to match up the size for you. In the U.S., a European shop would be the first choice since the cooling system is probably German in origin (and those fittings are made by the German company Norma). For other components, such as Denso sensors, an Asian shop might be better, since the O-rings may be sized according to the Japan Industrial Standard. In my shop, I keep several assortments of metric O-rings and it has been some of the best and most time-saving money I've ever spent.
You might find a close-enough fit in the plumbing department of a hardware store, but the Buna-N O-rings for potable water are typically only rated to 250F/121C, which is borderline in an automotive cooling system.
Depending on the manufacturer, metric O-rings are sized by their cross-section and inside diameter (I.D.) or outside diameter (O.D.), so a typical size would be something like 2.0 X 6.0, where the cross-section is 2.0 mm and the I.D. is 6.0 mm. You can calculate the O.D. by adding the cross-section times two. For manufacturers who use the O.D., you subtract the cross-section times two to calculate the I.D.
Cheers,
Don
A.J.P (04-24-2019)
In most auto parts stores in the US, there is a Dorman display of odd parts: usually there is a bag of o-rings of many sizes. Sometimes they are sold over with fasteners. The last bag I bought (I needed an o-ring for the dipstick) had about 30 different rings, usually two per size. But, I will bet it will still leak due to small fracture -- order the new pipe and be done.
Most of us have broken these: just too handy a hand rest while redoing water pumps and thermostats and drive belts. Bought a new one, after trying to seal the broken one. Replaced it. Took the car in for a dealer oil change (because of all the Land Rovers, Checker Flag Service loves me and sends all these coupons). Checking the car out, I notice the new pipe had now been replaced by an even newer pipe (at no cost). Apparently even the pros put their hands in the wrong spot . . .
Don B (04-24-2019)
Gibbo205
09-11-2018 09:41 AM
