Jaguar XJ8 2001 code problem P1111 engine does not start
Old 10-13-2011, 03:54 PM
sajmonides's Avatar
Default Jaguar XJ8 2001 code problem P1111 engine does not start
My 2001 Jaguar XJ8 does not start. The engine does not turn over. The only code I get is P1111. Any ideas?
Old 10-13-2011, 09:04 PM
Received 8,119 Likes on 4,901 Posts
DEAD battery???????
Look at the power post on the false bulkhead , right side engine bay behind the suspension tower. They get hot/melt the brass/copper stud and the starter/alternator/battery wire makes no contact.
just a guess??
bob gauff
Old 10-23-2011, 07:56 PM
sajmonides's Avatar
No, it's not a dead battery. I shouldn't have said "turn over". It does turn over but it doesn't start. I'm clueless.
Old 10-23-2011, 09:45 PM
Check the fuel pressure. Remove the engine covers and look for a small cap that looks like a tire valve cap. Gently push on the schrader valve in. A good fuel pump will have pressure and fuel will squirt out. A bad pump or related items will not squirt. Try that.
fast40driver
04-19-2024 07:24 AM
1964Daimler
09-02-2015 11:41 PM
Drew2006
08-28-2015 04:22 PM
NinoGrimace
08-26-2015 05:15 AM
souldoubt
08-25-2015 08:15 PM
Quick Reply: Jaguar XJ8 2001 code problem P1111 engine does not start
