Jaguar xj8 4.0 2001.t.c and asc displaying unavailable any ideas y
Hi all everytime i start car i have t.c and asc displaying unavailable.traction control is fine.no issues with engine or runni gear as yet.small problem when starting dont always start ist or second time usalky 3rd time.so any suggestions of problem with t.c asc .thanks
I would suggest you fit a new battery, the long cranking could be a dying fuel pump, but see if the battery cures it first before going into diagnosing an issue that could be the battery condition.
Jaguars are very cranky about a low battery and will throw a hissing fit. Another thng they don't like is being rushed to start. When you turn the key to on count to 5 and then hit start. See if it cranks up better.
When the key is turned to the on position it turns the fuel pump on for 3 to 5 seconds to allow it to charge the fuel rack. If you stick the key in and go straight to start the rack doesn't have enough pressure to fire correctly causing you to have to try again.
If it continues to display that warning after you change the battery, the problem is likely within the ABS module. There are a couple of soldered connections that are known to crack. It's a matter of removing the module from the car, opening the box up, resoldering all the solder joints, replacing the cover (glue it on with epoxy for a weather-tight seal) and reinstalling the module back on the car. It's not technically difficult but getting the cover off is a bit of a pain. I'll post a link to one of the procedures that I used...
Modern Jaguars are extremely sensitive to battery condition and charge. It should always be the first thing to check and eliminate in the event of unusual electronic behaviour.
dsetter
02-02-2024 11:57 AM
Smudge67
02-01-2018 07:03 PM
