Jaguar XJ8 4.0L valve cover gasket replacement - Video
Great job, that shows everything you need to know for the job. It's the same procedure on XK8's too, maybe a moderator could add these to the sticky video and workshop manual threads.
Thanks for taking the time to do these videos. Great for the first part of the secondary tensioner job to.
RSpi. Thanks for the video. I did my gaskets the day before the video. Replacing the bolts into the cover prior to reinstall is helpful, would have saved a bit of my time. I used some sealant to hold the gaskets on, the bolts will hold the gasket on without the need for sealant. Thanks again.
jimmy6565 (09-27-2022)
In my experience, Victor Reinz is one of the worst. I've put them on S-type V6's & V8's as well as X308's and they would come back leaking soon after. The seals are actually thinner and the bolt seal washers are thicker so to compensated. Stay away from VR!! Last I remembered is that the dealer will only sell you a complete valve cover with bolts and seals fully loaded. $$$$$
xjrjag
10-27-2021 11:48 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
