Jaguar XJ8 Antenna Mast Replacement - Video
I put together this video when I replaced the antenna mast on my brother's 2003 XJ8. I actually did NOT have to remove the motor because whomever broke the antenna off, pulled all of the mast rip cord out with the end of the antenna. I had no way of knowing that so I pulled the motor.
This video will show you both ways. I hope it explains it all for everyone that needs to replace a broken antenna.
NOTE: It is a good idea to lubricate the antenna shaft monthly or every so often with WD-40 or some other lubrication so the antenna doesn't get stressed when dry.
The following 3 users liked this post by RSpi:
Will P
08-27-2015 06:52 PM
Jaguar Forums Editor
Jaguar Press release
08-27-2015 03:18 AM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
