Jaguar XJ8 Odometer Not working
Just bought myself my first Jag - an XJ8 '98 3.2.
Only problem with it is the odometer isnt working. Its just blank so i cant see anything on the screen. The rest of the instruments are working fine, speedo etc..
Does anyone have any ideas what this may be? The lid to the fuse box in the engine bay is also missing so i cant check which fuse it is that may be linked to it.
Last edited by GGG; 07-15-2013 at 08:56 AM. Reason: edit typo in thread title so it appears in searches
The LCD is a plug in module inside the instrument cluster. Chances are it has failed.
You can replace the entire instrument cluster, but you will have to match up the exact part number and software version, plus the odometer reading will not be correct for your car.
I would recommend instead finding the cheapest used instrument cluster for a '96'-'03 XJ on ebay, and just swapping out the LCD module inside the cluster.
Welcome to the forum MrJagXJ,
+1 to the LCD Module. You don't want to get involved in swapping the full Instrument Pack if you can possibly avoid it.
I've edited the typo in your thread title so it appears in searches.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST section and post some info about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
MrJagXJ (07-15-2013)
At ths point it would be easiest to just replace the entire dial assembly including the LCD with the one from the the donor cluster. If you choose instead to remove the LCD alone, you need to peel back the bottom part of black plastic dial label, which is attached with adhesive to get the LCD free.
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Will P
08-27-2015 06:52 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
