Jaguar xj8 transmission fluid drain
Hi Yáll
I read in a forum that you can drain more fluid from the ZF 5HP24 auto transmission if you disconnect the return hose from the fluid cooler.
I believe the return hose is best disconnected where it enters the transmission.
My question is, which hose is it? Do you know which size tool is used?
