Jaguar XJR-100 (Brembo) Wheel Hub
Does anyone have a link on where to find a front wheel hub/hub carrier/wheel bearing & hub assembly for my XJR-100? Can't seem to find anything outside of the dealer on this one. Of course, it would need to be Brembo specific.
I saw on XK8 Parts that they can refurbish them...although that would be quite a bit of awkward downtime.
Thoughts?
David
Thoughts?
David
Unless you have damaged the hub or vertical link a competent foreign car shop can change the bearing in a day. SNG Barratt has the oem bearing for around $90.00 and an aftermarket for around $35.00.
You can send them a parts request and they will qoute what they have. You can do the same with Jagbits or Welsh. All are forum sponsors. I have bought parts from all three with good results.
