Jaguar XJR 1999 - smoke
HI FOLK IM NEW TO THIS FORUM TALK BUT RECENTLY FOUND A LOT OF USEFULL INFO ON THESE SITES REGARDING THE PROBLEMS IM HAVING
MY CAR DEVELOPED A MISFIRE ON CYLINDERS 7/8 .OIL WAS FOUND IN THE PLUG WELLS AS SUSPECTED SO STRIPPED DOWN REPLACED ALL CAM COVER GASKETS ALL PLUGS ONE FAULTY COIL.ALSO A FAULTY SECONDARY TENSIONER (METAL) PLUS FITTED A NEW K&N PANEL FILTER AS THE LAST ONE WAS FILTHY.WHILST THE CAR WAS OF ROAD I DROPPED THE OIL AND PUT IN 10-40 AS THE CAR HAS COVERED 118000.
I AM UNSURE OF THE SERVICE HISTORY OF THE CAR AS THE DEALER HAD LOST THE HANDBOOKS I AM LED TO BELEIVE THE CAR HAS THE LATER ENGINE INSTALLED+CAR FEELS A LOT FASTER NOW BUT UNDER HARD ACCELERATION ITS BLOWING OUT BLUE SMOKE BUT CAN PARK UP AND REV ITS NUTS OF AND NO SMOKE AT ALL .BUT THE FOLLOWING WORK HAS SOLVED A BURNING SMELL(OIL ON MANIFOLDS)RATTLE AT IDLE TENSIONER .. CAN SOMEBODY SHINE SOME LIGHT ON THIS FOR ME
![Icon Sad](https://www.jaguarforums.com/forum/images/smilies/icon_sad.gif)
Welcome to the forum Kelky,
I've moved your post from General Technical to the X308 section where it should get a wider and faster response.
I must warn you the first reaction you're likely to get is about using ALL CAPITALS AND NO SPACES which is a good way to upset members because it's very bad to read.
Kelky (08-27-2012)
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
FS[MidWest]: FS: 1999 VDP *lots of pics* in mid-Missouri
souldoubt
08-25-2015 08:15 PM
