Jaguar XJR Restricted Performance
My XJR gave me Restricted Performance code and when I went to try and read the system with an OBD2 and it said, "Can not connect to ECU". My engine also was running some what rough and was wondering how to go about diagnosing the issue. Also, was wondering if this could be just a bad battery issue the battery I have is 6 years old and has been recharged a couple times, and my dash and lights are dimming in and out. Only reason I don't want to swap batteries is because I'm curious if there is a bigger issue, and don't want to delete the fault codes.
That battery sounds suspect and these cars don't do well with low voltage. I would check to make sure you're getting the proper voltage throughout. I've attached an electrical trouble shooting guide; skip the hard reset part (the pages aren't numbered) and go to the one with "First, a Little Electrical Theory." Then do all of the voltage checks.
mikebaker3
07-14-2018 05:57 AM
Jag400
07-07-2011 05:05 PM
