Jammed Rear Seat Belt
You will have to remove the rear seat. the belt has become twisted,it is an easy job to do. remove the fuse kick panels,undo the screws holding the bottom seat make sure to unplug the seat heater plugs.lift it out then undo the screws that hold the back seat lift upward then you can get to the seat belt. hope this helps
WinterJag
16
10-09-2015 07:49 PM
