Jammed starter
Received 2,677 Likes
Begin by checking battery voltage with the ignition in the OFF position for at least ten minutes. Check voltage across the terminals, which should be a minimum of 12.6 volts. If it's less, charge the battery overnight and test it again. If you still have less than 12.6 volts, the battery must be replaced.
Depending on the number of kilometres/miles on the vehicle, the starter may be failing. Check for voltage at the starter with the key turned to START. If there is no current to the starter solenoid, check the relay and swap with one of similar design. If relay function is normal, check wiring loom.
If the starter is indeed failing, it's best to remove it and have an automotive electrical specialist overhaul it. I have not had much luck with the 'remanufactured' units sold at the various parts houses.
Over the many years I've replaced/rebuilt starters, I always coat the starter bendix gear with lithium grease. Once installed, the grease coats the ring gear in case there's a rough spot on the ring gear teeth. I learned this watching a technician at a Dodge dealership overhauling starters. I never saw a comeback.
