Jaugar XJ8R.1998
Hello I still have problem with my jag gearbox changed oil / filter still the same problem fault codes PO730 & PO780 and gearbox light comes on gearbox fault any one knows what is it.once car goes its fine could drive all day gears change fine stop for hour than problem no gear change or want go forward than switch it of restart its ok somes times do few times swith of restart before you can drive it I dont think there is fault in gearbox may be gearbox ECU
Received 1,794 Likes
Wow: a keyboard without a period. Dude, your description of the issue is really hard to read without punctuation.
I would suggest that you take it back to the dealer who changed the fluid and filter. I agree with Highhorse, sounds like you are low on fluid. But the dealer's diagnostic software can read the fault codes.
bobbkc
09-25-2017 02:15 PM
jlindy
12-09-2011 09:01 AM
