Jiffy Lube OK or "No Way!" ??
Received 10,912 Likes
Fair enough but an oil change is really one of the most fundamental automotive procedures. If those being paid to do so feel underpaid then they should charge more. If I pay for a job I expect it done right. What the oil change joint did to my Wife's car was no opps. Some people make mistakes and some people are incompetent and some people set you up for a problem. If you ever have a $35 oil change turn in to a $2000 bill you would lean my way I bet!
I'm not against you :-). They bollixed up your car. You have every right to be angry.
I agree that they should charge more and hire higher grade, higher paid, and better trained mechanics so as to minimize the risk of incompetent workmanship and/or obvious negligence.
There's no getting around the occasional human errors, though. Those are usually the result of working too quickly....rush rush rush. They should slow down, even though they have 15 cars waiting ...with each customer tapping their toe.
Of course, if they charged more and worked slowly, they wouldn't be "cheap and fast"....which sorta takes me back to my first posting :-).
Definitely due to litigation, when you have them do tire work, they will now torque every nut, take the car for a drive which includes two full figure eights, and then retorque everything. I think that's overkill, but had no qualms with them putting new rubber on the Jag... they were really tickled to work on it and treated it right.
They have a purpose - to change oil for the masses - for the hondatoyofordgmlins that are almost identical and require no forethought, to remove the oil and filter and replace it again, from a worker that has little education and probably a less than rosy future...
That said, we expect more from our automobiles AND from our service technicians. If we don't do it ourselves, we are willing to get it done right and pay for the privelege.
I might take my son's Taurus to Jiffy Lube, I sure as hell won't take my Jag.
What??? I wasn't supposed to do this? But I saved $125 bucks! I even took her out to a nice dinner with some of the savings just to calm her back down... Something about too many Dr's wanting to verify the first Dr's findings... I don't know, they wouldn't let me into the exam room for hippa reasons.
#28
I use them, I check them, I pay them less. Even trusted mechanics will screw up. I also only use them for the basics; oil change, air filter, that's about it. I personally have never had a problem, though I have heard plenty of horrow stories.
You do have to do the QC thing, but that is a lot faster than doing it myself.
I must say I resonate with the thought that laying under the car and watching it drain is about as much peace as I get. It is a good place to hide when the wife is in a mood...
#30
Considering the volume of oil changes these outfits do the defect rate, as a percentage, probably isn't all that bad.
I've been known to take a little nap while I'm under the car :-)
#31
This is exactly what our trusted, independent service dealer does, and is why, if you care for your car, you don't go to a jiffy style lube joint.
Now, one advantage to Jiffy Lube, is the tech is right there. Got caught once out of town with low diff lubricant. The tech did it exactly the way he was asked to, with the right LSD lubricant, in about 5 minutes on a Sunday. As for why the diff was low, you'd have to ask the "trusted independent mechanic" who filled it in the first place.
https://www.jaguarforums.com/forum/s...ad.php?t=51496
pet peeve - missing fasternsers after service
#32
As noted above, there is *nothing* stopping anyone from checking the dipstick before departing from either a Jiffy Lube *or* a dealership.
Indeed, at Jiffy Lube and other similar places, it is customary to show the customer the dipstick before the customer leaves. Presumably this is to prevent arguments after the fact.
#33
I spent most of my life running dealership service departments and, yes, it DOES happen from time to time...even with the old pros.
For a couple years we went on a "30 minutes or less" oil change promo. The number of mistakes increased measurably. Rush rush rush!
We all know there are no guarantees. I still maintain, though, that your chances of oil change happiness are better at a non-quick lube type of shop.
#34
The Jag is not that same thing as the Honda or Toyota (just as bacon and eggs is not the same as creme brulee) that they can do in their sleep, it requires a little thought - it's unusual and so are its requirements.
And yes, it MIGHT happen at my independant dealer... but I'll bet dollars to donuts that the odds are a whole lot lower.
#35
Notice that I specifically talk about oil changes and none of the add-on services. Not flushes, not tire rotations, or anything else.
The Jiffy Lubes of the world do one thing, and one thing only .. oil changes.
That makes them oil change specialists. It is their core business.
The comments are not directed at swaying anybody to use such places, but only to point out that some of the criticisms are not warranted.
As far as being unusual, well, actually taking the time to talk to the person doing the work does wonders. The employees generally like cars and take an interest. For them, a Jaguar is a break from the usual fare. Just like it is for the owner.
#37
True, true ! And McDonalds is a hamburger specialist....but my expectation of a good meal isn't very high :-)
For a *good* hamburger there's a restaurant here in my little town called "The Masthead". Yum.
Of course it'll cost me $9.50 and take a lot longer than 1 minute and 41 seconds to get my meal :-)
All these food analogies are making my stomach growl!
#38
#39
Plum, I'll agree to meet you in the middle as we're going to have to agree to disagree a bit... I just don't want the ham-handed oil pushers inside my hood, where a simple, inadvertent bump up against a breather tube or assorted connectors can end up causing a limp mode and subsequent troubleshooting (translation: MY labor) a week or two down the line.
They may well be 'experts' on changing oil, as they probably see 500 Camrys and Preludes per month... but how often do they see an X308? I'll bet not very often.
Regardless, our points have been made and I respect your opinion.
#40
