Just bought a 98 XJR, have a few q's:
I figured I would chime in here- My Pulley came loose, fortunately I was close enough to get home...
I thought the pulley had come apart, but when I pulled on it, it came right off. Doesn't look like the car has been worked on before I owned it, so I have to believe it loosened itself. Ordered a new cone and bolt, so I should be back on the road by Tuesday. I also have never come across such a weird situation... for the poster, you are going to have to find a used one, no way around it.
Hi
Jaguar Electronic Parts Catalog shows the split collect (your cone on the crankshaft - described as between damper [pulley] and crankshaft) part# NCC1450AA .
I looked this part number up on Gaudin Jaguar Parts online and found it has been superceded with part# AJ89854 - retail price is $37.50 discount down to $30.46 plus shipping.
Jim Lombardi
Jim Lombardi
I am convinced it came loose because of the wobble (distorted rubber) created from the tension of the supercharger belt while it sat for three years. I did not see any evidence of prior work, and I bought it with a broken upper timing chain which I replaced without removing the pulley. I suppose it is possible someone tried to loosen it and start the work, then stopped and re-tightened it when they were told no.... I doubt it is very common, as I had not run across it in all my reading over the last 9 years or so in Jaguar forums.
plums (02-16-2012)
#30
Woodruff key: Mine did not have one, the tightness of the bolt holds the pulley in position
Cone washer: The cone IS the washer.
Three parts:
Pulley
Cone
Bolt with Pink loctite
If you buy a new pulley, I would be interested in buying your old one- I would send it out to be repaired and use it on mine if the metal isn't too damaged.
D
Three parts:
Pulley
Cone
D
#32
HI
PDF file extract from JTIS21 shop repair manual that covers the Removal & step by step installation instructions & illustrations for the Crankshaft Pulley and associated componets (98 XJR).
98 XJR Crankshaft Pulley R&I.pdf
Not sure why the woodruft key is not shown or mentioned in the above ????
Jim Lombardi
Jim Lombardi
#33
HI
Attachment 16953
Jim Lombardi
Attachment 16953
Jim Lombardi
The woodruft key is for the oil pump. The pulley has no key. Definitively get a new bolt and cone. Reusing it is probably the reason why it came off the 1st time.
jaguars4r (02-18-2012)
#34
#35
Three parts:
Pulley
Cone
D
Three parts:
Pulley
Cone
D
Yes, but what is #11 in the diagram pic? Where does that go? It seems like I need the bolt, pulley, cone and whatever #11 is?
#36
jaguar4r,
I'm in Brisbane, Australia and my bus partner dismantles jags. If you don't/can't find a front engine damper (pulley) over there, let me know & I'll ask Murray if he has one. You'll need to privide your VIN & Engine number so he can check to make sure that you get the right one.
Incidentally, Nikasil engines were fitted up until April 2000: the engine number can also tell you whether it was a Nikasil or not. Keep in mind that engines which were installed as replacements under warranty can still be Nikasil. Only the engine number can identify which type is in the car.
I would agree with the observation of QuadManiac: it would seem odd that the damper was out of round, they are a bloody solid lump of steel. Unless it was grated along the tarmac it is difficult to comprehend. Perhaps the rubber bushing is damaged, or perhaps the crankshaft is worn out of round causing the damper to 'throw' during operation. But I would seriously doubt that it is 'out of round'. That sounds like 'car salesman spiel' to me. It would seem that he has little mechanical knowledge about engines, but wishes to appear knowledgable & so has created a story to fit what he sees.
I'd suggest that you make the purchase subject to a mechanical inspection by a proper workshop of your choice (not his), because if the crank is damaged, the engine will have to be pulled out & semi stripped down to repair or replace it. It won't be able to be done while in the car.
I cannot comment about the price there, but in NZ in good nick with those miles it would be worth about $12,500 to sell. That's about $10,000 US, but it would need to be in good condition generally.
#37
#38
I got the pulley yesterday from Adam and ordered all the new parts from the dealer today, bolt, cone, crankshaft seat and that #11 washer, so when I put it all back together next week (since dealer doesnt have the parts in stock) ill let you guys know how it goes, also, what do you guys use to lock the pulley when tightening? I was able to use a bmw trans bolt 5hp-24 that fit right in the flyweel, kind of worried that it might snap though since I have to torque it to 350tq
#39
