just bought my first jaguar! (gearbox fault?)
Old 01-21-2018, 01:22 AM
justas696661's Avatar
where 2nd TPS is located? and what is TPS anyway???
sorry for my poor knowledge
Old 01-21-2018, 01:48 AM
Lady Penelope's Avatar
Received 1,387 Likes on 1,090 Posts
Throttle position sensor tells the ECU the amount of opening position of the throttle butterfly . This value will go from 0 % closed to 100 % full open . Geometry O to 90 degrees is not used as a reference . The ECU gives the sensor a highly controlled reference voltage say 5.0 volts and is modified and goes back to the ECU as a changed voltage compared to the reference voltage . That's how the ECU " sees " the 0 % through 100 % butterfly position .
I have the inline 6 cylinder but the sensor on the V8 is on butterfly pivot axis .
Old 01-21-2018, 02:43 AM
i believe i can see that through obd2 scanner, ?
Old 01-21-2018, 04:59 AM
look at this video, is this normal? i push pedal to the bottom, and why it's not 100?
Old 01-21-2018, 05:14 AM
phanc60844's Avatar
Originally Posted by justas696661
and plus acceleration is not so good with my jaguar.. today i tested friend xj8 4l engine and it starts from stop light like insane.. mine is not,. feels like you start to drive with 2nd gear, but it's 1st gear.
very very sad day today..
It does start off in 2nd gear if sport isnt selected
Old 01-21-2018, 05:38 AM
ericjansen's Avatar
Received 1,354 Likes on 928 Posts
Common problem, it is either a combination of too much play in the cable and the accelerator pedal stop wrongly positioned, or one of them.
You will first need to take out any slack of the cable, which you can do at the cable end at the Throttle Body.
Lift the small square which holds the cable, and turn it left or right to slacken or tighten the cable.
If you see the valve opening not returning to the base value (~2.5%), you turn the square a tat back.
Then check the accelerator pedal stop. In your case it might be just a stop, otherwise it is switch.
You can check by trying to push it, fixed or clicking.
If it is a stop, just turn it left or right, till you get 90-92%, not 100.
If it is a switch, do the same, but you have to be careful with the wires underneath, which are easy to break.
Basically the stop can only turn some 30 degree, but if you are not sure, pull the carpet up and watch the wires.
Old 01-21-2018, 05:41 AM
ericjansen's Avatar
So, did you check your spark advance now?
  #28
Old 01-21-2018, 06:02 AM
yes spark advance is 4-5 idle, 30 and more when accelerate.
i have adjusted this one, and now i have 100% when i push pedal to the bottom, i think this was the problem why my acceleration was slow.
https://i.imgur.com/Wtu1XIT.jpg
will be doing test drive soon
Old 01-21-2018, 10:13 AM
looks like it drives better now, even without sport mode it accelerates till 6800rpm. BUT it's still slow from the start, here is the video i made.
​​​​​​what you think?
and video with good acceleration i found on youtube
  #30
Old 01-22-2018, 06:04 AM
today i will try to look at 2nd TPS that feeds the gearbox ECU , maybe there something is wrong, now jaguar drives very good, , expect it's VERY sluggish at take off.
  #31
Old 01-22-2018, 06:07 AM
also will try to clean whole throttle body.
and one my friend said to look at MAF readings, ,what normal MAF values should be?
C_Dub
07-23-2011 09:31 PM
mutisync
01-11-2009 03:20 AM
colmcassidy
05-04-2008 12:16 AM
Jag9891
05-04-2008 12:12 AM
Quick Reply: just bought my first jaguar! (gearbox fault?)
