Keep getting a p0174 (lean right bank) code
Old 03-03-2018, 09:18 AM
yeldogt's Avatar
Originally Posted by RJ237
I'm not sure that we're getting through to him. All the suggestions to throw parts at it should be put on hold until there is more data.
CHECK THE FUEL TRIMS.
That's why I said "would be looking".
I can't remember ever getting a hard O2 sensor code w/o eventually needing the sensor ... if not an immediate need.
We actually had some difficultly testing the fuel pressure -- it was always OK (when we checked). And the symptoms directed elsewhere ... it's always difficult situation when an intermittent issue does not show itself.
I'm not one to throw parts at an unknown problem -- unfortunately, sometimes the alternative is an unreliable car .. and that's not acceptable.
The R will energize the second pump initially on startup of ignition -- then the primary pump runs until the second pump is needed at high fuel use. I must have had two partially working pumps.
Old 03-04-2018, 08:24 AM
TreVoRTasmin's Avatar
I have and it didn't look too out of the ordinary to me. I just haven't been able to screen shot it and put it up here for someone with more knowledge on that to look at. Car has been running just fine sans light again for the past 100 miles.
RJ237 (03-04-2018)
Old 03-04-2018, 08:52 AM
yeldogt's Avatar
Just understand, as I said above you may be having 2+ issues (like I had) .. I'm not sure why the trim level lean would give you the restricted performance engine management outcome ... you would get the CEL when it occurred (I think two hard cycles). I never got any CEL light .. I could only feel a slight power loss if at very steady speed and smooth road .. not enough to even give me a knock warning.
Old 03-04-2018, 02:40 PM
JagV8's Avatar
Received 4,551 Likes on 3,958 Posts
Don't screen shot. Type the values in.
Abe Mirza
07-19-2023 08:53 AM
JCam
07-02-2018 10:38 AM
juliovega914
09-24-2012 11:18 AM
stevis05
03-16-2010 07:49 AM
Abe Mirza
01-30-2010 10:41 AM
Quick Reply: Keep getting a p0174 (lean right bank) code
