Kenne Bell Supercharger Upgrade?
Received 2,191 Likes
It's a really good mod, but expensive. $6000 plus labor. You have to ask yourself if its worth it considering the strain you'll put on the drivetrain also.
It's probably better to go with some upgrades and get closer to 475-500hp.
@Brutal I was considering the Eurotoys/PSE Superchargers porting and pulley upgrade. They claim the porting gains 30hp and the pulley will get 30-35hp. What do you think?
The drivetrain is pretty strong, have had several twin-screw setups on my car now for over 80.0000 miles, and so far mine is holding up very well (most of the time about 430rwhp).
The kit I have developed is based on the 2.6H Kenne Bell, and would also fit the 4.0 XJR.
Am currently investigating if I split it in a Stage 1 and 2 versions, but that will depend on some more test I am currently conducting. I do hope to have it sorted in the coming weeks.
I have now 160Kmiles on my car, with 90K I would say the engine is nicely run in ;-)
The advantage of a twin-screw is that it consumes less power from the engine, at least 30 rwhp in stock form and similar PSI, and the difference becomes bigger compared to a twin-screw if you start spinning the Eaton faster.
So adding 30 rwhp more with an Eaton, is more stressful to the engine then getting 60 rwhp with the twin-screw.
One of my older setups with a 2.1L Kenne Bell delivered about 375 rwhp with 12 psi compared to 315 rwhp with the Eaton in stock form. That setup wasn’t even close to the efficiency I have now, but I think you get the picture.
the biggest strain to the drive train would be putting slicks, or drag radials, tuning the torque convertor to increase stall. Then you could worry about driveline strain. the ecu on shifts is still going to cut torque output temporarily by shutting off the fual injectors to smooth shifts(you can see this with a air to fuel gauge hooked up in the car) and with traction control will also limit power and wheel spin. As power goes up and you turn off traction control, then your tires will limit stress to the drivetrain cause theyre just gonna go up in smoke without prudent gas pedal usage. I wouldnt be concerned with the increased power output as Avos has pointed out through his real world experiances with his cars. And Jaguar built their own 510hp supercharged 5.0 useing basicly the exact same drive train. And since they will not push a car past its capabilties for warranty issues and cost, you can rest assured theres more to be had safely. If something is gonna break, its gonna break stock too. Please remember that forums are good for evryone coming and looking for answers to BROKE cars, so it can seem like theyre alot of failures, but as a % of the cars out there and the failure rate. It is still small
Naso--Lituratus (04-01-2015)
update: nevermind, I see that you developed it yourself. What is the cost? Lead time?
Agree fully with Brutals post, the TCM indeed sends a torque reduce request to the ECU when it wants to shift (yep another mod for the dyhards ;-)). Would also like to add that an LSD also puts more stress on the drive train, but so far it has worked out for me though I know the extra styress it brings.
I am trying to figure out if I can still make efficiency improvements, will need about 1 more week, chances are that I will split it in different stages as mentioned earlier, and then the good news is that stage 1 is ready.
Please send me a PM if you are interested.
AVOS' KB setup will have at least 75-100hp(I'd guess closer to 150hp) over the stock. You'll be able to run with the E55's and M5's 0-60 no problem if they're not modded, but they'll get you in the 1/4 mile. Most people run from stop light to stop light so dont worry.
please remember too that twin screws like Kenne Bell, Whipples and TVS's are TRUE compressors. Not an air pusher like a typicle roots(Eaton) the twin screws build max boost almost instantly instead of the linear climb of a typicle roots blower. So you have to look at what you get for power below peak also, its alot more power output lower pound for pound. And that can make a huge difference on everyday driving and stop light warrioring
I find your comments about the E55 amusing as I have not yet installed a twin screw supercharger but have done every other mod possible & 2 years ago with a 3.27 non pozi diff fitted to my car I have seen as low as 4.06 seconds 0-60 on a cold day. I now have a 3.58 pozi & within 2 weeks will have a 3.77 pozi fitted. I would love to see any E55 stock or modofied try to keep up with me.
When my car was stock it made about 310 rwhp, and assuming a 17% drive train loss that would be about 364 engine HP. Will have to do some new dynos as my previous ones early this year where not valid, those showed 550 rwhp, wrong setting in the dyno software…
Not sure yet what the max power is that can be had with this kit, will do some more testing the coming weeks. But I already had 470 rwhp (stock ECU tune/Stock Exhaust/relatively mild pulley combo) which would be about 553 Engine HP, and I am hoping on more than 500 rwhp (602 Engine HP), let’s see.
So this kit would bring at least 150 extra Engine HP (if the 17% drive train loss is about right), probably closer to 200 engine HP pending some other mods.
Am not familiar with an E55, but do you think they can keep up?
Thats all the Mercs and Bimmers have on us is a better gear setup. Acceleration vs MPG. Unfortunatly we get MPG. If it wasnt for the presence of a clean Jagaur, they really wouldnt be appealing to many for the price vs competitors in its class.
If you do have gear info please let me know.
You undoubtly did a heck of a job with the Jaguars, but you are still fighting a losing battle vs the Mercs.
I LOVE my Jaguar because of its character and I wish it came with stock 450hp, but to try to put $15k-$20k in mods just to keep up with a stock E55 is a bit off the wall.
