key cant get into the keyhole all the way
Hi,this has been an on going issue almost ever since I have purchased the car but I think it is time to pay attention on it
initially, key worked fine at the door since I did not even have my fob yet. Once I programed a fob (perhaps not even related) , I realized I cant put the key all way in the keyhole anymore but it only takes like halfway
I want to know what went wrong and how to fix it.
note:WD40 did not work
WD40 is not suitable for locks. It was developed as a water dispersant (hence the name) and is not a lubricant. Over time it dries out which is probably why your lock has become inoperable.
Locksmiths use liquid Graphite, powder Graphite or Houdini Lock Lube as a lubricant for locks. For a partially seized lock, the liquid Graphite or Houdini spray will likely be the most effective in freeing the lock and then keeping it lubricated.
vincent661983 (10-11-2012)
philwarner
28
07-11-2017 10:21 AM
Jzar
09-27-2015 02:55 PM
