key fob programming X308
i know that other people have been looking for this and i found this to work after searching.
Hold back on the direction indicator (high beams) put int and turn key to position I
and flash the high beams four times and the car will chirp indicating learning mode, and the security light on the dash will
light up. press down on the lock or unlock button and car will chirp when accepting the key fob. and it will
chirp twice when exiting learning mode.
someguywithajag (08-16-2018)
RE: key fob programming X308
also you need to hold one arm over your head, close your eyes hop on one foot while spinning around and this all needs to be done from the rear seat on the passenger side on the 4th friday of an even numbered month, while the sun is in its highest position.
None of this is true but that kinda seems like what they want you to do.
X308XJR
05-20-2019 07:50 PM
Jzar
09-27-2015 03:55 PM
zdrapec
09-25-2015 06:49 AM
