Key Ring Transmitter reset on XJ8
I changed the batteries on my key ring transmitter as it began to lose range and then stopped working and although I followed the intructions carefully the transmitter now doesn't do anything for the car (98 XJ8) The manual says the dealer can reset the codes, can it be done at home? Is there anything I'm missing (I've just acquired the car). Is it expensive if the dealer does it?
Any help would be much appreciated here. Michigan is at 8 degrees Fahrenheit which is about minus 13 Celsius and we need those key clickers working!!
Thank you.
Thank you.
RE: Key Ring Transmitter reset on XJ8
With the drivers door open, key in, hold high beams on, turn key to position 1 and flash high beams 4 times. You
will hear a chirp then press unlock button on remote. Turn ignition off, remove key and test remote.
this is same procedure for xk and xj.
You forgot a couple steps,
ORIGINAL: FactoryJaguarTech
With the drivers door open, key in, hold high beams on, turn key to position 1, clap your hands twice and say "beetlejuice" three times and flash high beams 4 times. You
will hear a chirp then press unlock button on remote. Turn around once, hop on one foot for exactly 5 seconds, Turn ignition off, remove key and test remote.
clubairth1
29
05-10-2024 12:57 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
