Key won't open XJR door
Hi - I have an odd issue. I've got the battery disconnected at the moment as I've been doing a few tidy up jobs on the electrics, so I manually locked all the doors overnight.
Today, I went to get in and could not open the drivers door with the key. Luckily I could get in the boot (trunk) and reconnect the battery and then it opened OK electrically from the remote. As a test I went through the process again and it would seem that although I can lock the car manually with the key, it won't unlock it.
Is this something anyone else has experienced? I'm probably going to have the door-cards off at some point to hunt down some rattles, and while in there should I be looking for something errant with the lock?
Cheers,
Tom
Cheers,
Tom
Cheers,
Tom
Cheers,
Tom
This was odd as I had the car for months before I got the remote to work, and she always locked / unlocked with the key .
To cut a long story short, she unlocked OK, but would still not lock with the key. Reconnected the battery and she locks / unlocks perfectly with the key ???
I played again tonight and I've discovered that with the key, if I turn it fully then the plunger descends further than when it locks electrically. At this point it seems to jam up on something which prevents it lifting back up.
So if I carefully "half" lock the door, then it will open up again OK.
Another little job for the list.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
