Keys locked in trunk
What it all means is that you remove your license plate and behind it you will see a circular sticker over a hole, open it. What Newuser is saying is that he used a flat screwdriver and pushed lightly on a small metal tab and the trunk opened.
You may need to read the entire post to understand further.
Thanks Gus for all your help on this issue, and the misfire issue. i replaced all my spark plugs and the car runs perfect again. I have a spair set, but i cannot get ahold of them until tomorrow so it is fine if i cant get them out, but i just wanted to get them out early so i could drive
The hole is where the screw for the license plate would go (bottom right). You have to remove the plastic piece that has the tread for the screw and once removed there will be a small slot. Note, my car didn't have the hole nor the plastic piece either because it was removed and painted over and the paint was covering the hole! So i just poked the hole with my finger to remove the paint and there it was. If you need details on how to get it open read what I did on the link above or email me.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
