Knock Sensor for 2003 XJR
Old 06-27-2022 | 08:47 PM
David N. Warner's Avatar
Default Knock Sensor for 2003 XJR
Hello,
I have recently purchased a 2003 XJR with a number of issues; the most pressing being needing a knock sensor. I have changed some over the years on my VDPs and I'm checking to see if the XJR sensor are the same? When looking online I have seen some that look quite a bit different. So the question is; are they the same sensors? I have attached pictures of the two I have seen...is it knock 1 or knock 2? Thanks a bunch!
Knock 2
Knock 1
Old 06-27-2022 | 10:13 PM
Addicted2boost's Avatar
Knock 2. The first photo. Do yourself a huge favor and change them both unless you enjoy pulling the supercharger off on a regular basis.
The bottom photo (knock 1) is for an earlier AJ26 engine.
Old 06-27-2022 | 10:14 PM
M. Stojanovic's Avatar
Knock 1 is for AJ26 engines and Knock 2 for AJ27.
Old 06-27-2022 | 10:25 PM
Highhorse's Avatar
I have knock sensors for a '05 4.2 in mine, ...they've been in since '18 with no issues. You need to search around, because you can find deals usually, but you have to hunt. I found mine at NAPA for a ridiculous $67 ea.
Old 06-28-2022 | 12:01 AM
RandyS's Avatar
Default Even cheaper
Yep, I noticed that Parts Geek had those for about $42
Old 06-28-2022 | 10:36 AM
Thanks Guys! Got 'em on order now!
Old 06-28-2022 | 02:06 PM
vincent661983's Avatar
I am on partsgeek site now and they are selling one for 127.58.
where did you see 42 dollars?
I need to get mine also ?
Old 06-28-2022 | 02:27 PM
RandyS's Avatar
https://www.partsgeek.com/9lzl8pz-jaguar-xj8-knock-sensor.html?gb=pp&cid=28884375&aid=4168799307&kid= 1100003047982
Right Knock Sensor - 2004-2005 Jaguar XJ8 - Santech/ Omega Envir. Tech. W0133-1655954
Review Fitment Notes
Part Number: W0133-1655954
Brand: Santech/ Omega Envir. Tech.
Notes: 'A' (Right) Bank
Position: Right
Condition: New
Shipping Options: Ground, Overnight, 2 Day
00XJR-TJM
04-11-2022 11:45 AM
xjrmageddon
10-11-2018 06:06 PM
Peter14
05-27-2018 09:13 AM
Carnival Kid
04-01-2018 01:39 PM
wordman
02-01-2013 12:12 PM
Quick Reply: Knock Sensor for 2003 XJR
