knock sensor bank 2...even after new sensor
so I swapped the plugs and the error moved to bank one?? If I swap sensors the error stays on bank 2. So whichever sensor I mount to bank 2 on whichever plug I go into throws the code.
What could cause low input from the mounting point?
I have tried three sensors in that position now, all throw the code right away.
Since the sensor does not set a code when it is not fastened to the block, a zero-cost experiment would be to bolt it down in its original place with LESS TORQUE. Say, 10 ft-lb instead of 14. I remember reading somewhere, maybe on this forum sometime back, that the output of the piezoelectric stack (which is how these work) depends on the compression with which it is mounted.
Anyway, won't cost anything to check and might provide some food for thought for the rest of us.
derek15301xjr
10-20-2015 07:39 PM
Poet
10-06-2015 09:40 PM
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
