Knock Sensors
Old 09-01-2012, 07:31 PM
WadeRupe's Avatar
Default Knock Sensors
I recently purchased a used 2001 XJR engine & Transmission with 15k miles on it and had them installed in my 1999 JJR. Works good, but it sat in a junk yard for 8 years and the mice probably eat throught a lot of the hoses and cables. The car is running in restricted mode and my mechanic wants $1,200 to replace the knock sensors. I can do a lot of work myself and want to try to do this job as almost all of it is labor (supercharger has to be taken off).
Has anyone attempted this on their own?
Thanks for any advice...
Wade
Old 09-01-2012, 08:19 PM
jimlombardi's Avatar
Received 1,622 Likes on 874 Posts
Welcome to the forum.
Here is a weblink to a bunch of PDF files pertaining to Supercharger removal & install that includes all of the other related parts that will need to be removed. Post#1 has links to the PDF files:
https://www.jaguarforums.com/forum/x...f-files-58889/
Before you remove the throttle body, made sure you have a tool to remove the quick-connect that is part of a vacuum hose you need to remove from the throttle body. I broke it and the hose retails for $80.
Also here is another weblink to a DIY thread on how to change knock sensors (look at post# 1):
https://www.jaguarforums.com/forum/x...t-1-2-a-76815/
Jim Lombardi
Old 09-02-2012, 07:24 AM
steveinfrance's Avatar
In the XK8/XKR is maxwdg's account of removing his - still an on-going saga
Old 09-04-2012, 10:04 AM
WadeRupe's Avatar
Jim, Thanks a ton. I will grab the pdf's this morning...
magmedia
08-15-2019 08:54 PM
Poet
06-07-2019 07:54 PM
Poet
10-02-2015 09:00 AM
Dave1109971
09-30-2015 11:04 PM
Woznaldo
09-26-2015 11:02 AM
Quick Reply: Knock Sensors
