Knocking sound XJR X308
Hello all, I have a 1999 XJR X308. I was on my way to an appointment and noticed as I accelerated I could hear a slight knocking as my revs went up. The knocking is not present at idle and goes away at the shift points. I had no oil pressure light or overheating. I was about 2 quarts low when I checked. When I filled up the oil and started it again I heard a loud metal to metal sound. I drove about 5 miles and only heard the knocking as I reached the shift point. Any ideas?
faisme111 (06-08-2021)
motorcarman (06-09-2021)
If you had an aftermarket solid SC coupler installed (instead of the genuine spring-loaded one), it is possible that the knocking comes from the SC. Remove its belt and run the engine to diagnose.
The following 2 users liked this post by M. Stojanovic:
motorcarman (06-12-2021),
RJ237 (06-12-2021)
Steve W
01-03-2017 10:15 PM
