Leaking P/S Return Line
Good morning, gents
Came home from a recent trip out west to find the 100 sitting in the driveway leaking some kind of fluid. Got it up on the hoist to discover that the rubber line is cracked and leaking right where part #10 is located on this diagram, to the front of the clip/coupler.
My question to you is, is this repair as simple as disconnecting that clip, sliding a replacement chunk of hose on there, and clamping it back down again - or does this necessitate a complete replacement of the line and cooler? Only place I could find it was the dealer for $525+HST.
As always, your insight is appreciated.
Cheers,
David
Cheers,
David
Received 1,797 Likes
KidRock'n (07-01-2017)
As a matter of fact I do - I worked there in highschool! If I can repair the line via this method, that seems like a no-brainer! Thanks for the insight!
