Let's see some Sexy 308 Pictures
Old 09-18-2022, 07:10 PM
23racer's Avatar
Originally Posted by 87LC2
I absolutely loce that car @23racer !!! Don't think I've ever seen a BRG with the R1 package before, looks amazing.
And it goes like stink and stops on a dime. It also has the CATS active ride system. I don't know if this is standard on all XJR's.
c16rkc (09-20-2022)
  #1442
Old 09-18-2022, 08:44 PM
87LC2's Avatar
No, CATS is not standard on the x308 XJR. My 2003 R1 had it (like yours), but my current 98 does not. I liked the CATS system, but when I had to replace the shocks it was pretty expensive for OEM Bilstein units.
c16rkc (09-20-2022)
  #1443
Old 09-18-2022, 10:22 PM
23racer's Avatar
I am only the second owner. I bought it in 2005. Just loved the car when I first saw it. My knees went a bit weak, lol. Even today, when I walk away from it, I turn and look at it. Only car I have ever owned, that has made me do this for 17 years...
The following 2 users liked this post by 23racer:
c16rkc (09-20-2022), Roldano (09-28-2022)
  #1444
Old 09-28-2022, 05:54 AM
Oliver94's Avatar
New to the forums - this is my 1998 XJR
I've owned the car for almost two years now and it's a daily driver having done more than 20.000km during said timeframe.
Lot's of work and love has been put into the XJ and it is shockingly reliable thus far.
Greetings from Austria
The following 8 users liked this post by Oliver94:
Addicted2boost (09-28-2022), c16rkc (09-29-2022), Highhorse (09-28-2022), Highway Star (11-07-2022), neurojag (09-28-2022), Roldano (09-28-2022), Sean Miller (10-06-2022), Z07Brandon (09-28-2022) and 3 others liked this post. (Show less...)
  #1445
Old 09-28-2022, 06:18 AM
RandyS's Avatar
BRG is well suited to the XJR. Yours is an excellent example.
Is that a Cessna P210N you are doing a preflight on?
c16rkc (09-29-2022)
  #1446
Old 09-28-2022, 10:04 AM
Oliver94's Avatar
Thank you Randy. The combination grows on me as well.
Good eye! That is indeed a P210N we finished prior that day where our client does the preflight on his aircraft.
c16rkc (09-29-2022)
  #1447
Old 09-28-2022, 01:11 PM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
Most Welcome Oliver!
I really appreciate a well looked after example. Being a Nik engine it should easily cope with daily use, the only thing to be cautious of are 'cold start, move it 10 yards shut off' - this on-off process can cause the infamous 'bore wash'.
Other than that, if it's the original engine it will show very little wear on the bottom end and bores with regular oil services. Even at 500,000km! If there's a green tag, it's been replaced under warranty.
You're part of the best online X308 family now.
The following 2 users liked this post by Sean B:
c16rkc (09-29-2022), rsgensburg (09-29-2022)
  #1448
Old 09-29-2022, 06:04 AM
Oliver94's Avatar
Hi Sean,
thank you! Glad you like it. I really do look after it quite well. Thank you for mentioning it - I try my best to not cause excessive wear through unnecessary short moving of the vehicle. The engine is a certified OEM from late Nov 1997 with roughly 90.000miles.
The list of things I've already done to the car in the past months (while being a daily driver) is quite extensive but here is a little overview:
- All fluids changed (engine, supercharger, coolant, steering & transmission and differential oil)
- All timing chain tensioners and gaskets along the way
- Thermostat, expansion tank, temp sensor and the tachometer upgrade for accurate coolant temperature
- New steering rack, starter motor and false bulkhead connector
- New shocks (CATS), springs, bushings, new brakes (+ bigger front rotor upgrade), new rear subframe with PU bushings
- 18" Penta rims on winter tires, 18" Flute rims on summer tires
- HID headlights and full LED conversion on the interior
- Illuminated side markers (not standard on EU models) and customs side indicator relais that the side markers "blink" as well
- Black alcantara roof liner (including ABC pillars) and new speakers
- Footwell lighting front and rear
The following 7 users liked this post by Oliver94:
c16rkc (10-03-2022), earny (10-20-2022), Highhorse (09-29-2022), Parker 7 (01-09-2023), Roldano (09-29-2022), sov211 (10-03-2022) and 1 others liked this post. (Show less...)
  #1449
Old 09-29-2022, 09:19 AM
Quadcammer's Avatar
beautiful example. The interior is a little dark for me but looks to be in great shape. welcome and enjoy
c16rkc (10-03-2022)
  #1450
Old 10-01-2022, 06:34 PM
Quadcammer's Avatar
My offering
The following 3 users liked this post by Quadcammer:
c16rkc (10-03-2022), Highhorse (10-01-2022), Ken Cantor (10-01-2022)
  #1451
Old 10-01-2022, 07:33 PM
RandyS's Avatar
Very well done Quad.
The following 2 users liked this post by RandyS:
c16rkc (10-03-2022), Roldano (10-01-2022)
  #1452
Old 10-02-2022, 10:54 AM
Oliver94's Avatar
Thank you Quad, it indeed is very dark inside. Especially with the black headliner. Yours looks great too, I like the two tone beige interior.
What is your experience with the intake tube? Any noteworthy difference?
c16rkc (10-03-2022)
  #1453
Old 10-02-2022, 01:21 PM
Quadcammer's Avatar
Thanks! Intake tube i did along with a 6% pulley so cant say what it did alone, but definitely more supercharger whine and some extra power
c16rkc (10-03-2022)
  #1454
Old 10-08-2022, 11:20 PM
crash1121's Avatar
The following 6 users liked this post by crash1121:
c16rkc (10-10-2022), Highhorse (10-09-2022), Highway Star (11-07-2022), Roldano (10-10-2022), rsgensburg (10-10-2022), Timjag101 (10-09-2022) and 1 others liked this post. (Show less...)
  #1455
Old 10-10-2022, 02:52 AM
c16rkc's Avatar
What a stunning colour!
  #1456
Old 10-20-2022, 10:07 AM
earny's Avatar
c16rkc (10-24-2022)
  #1457
Old 10-20-2022, 10:21 AM
RandyS's Avatar
earny....looks like trouble?
c16rkc (10-24-2022), earny (10-20-2022)
  #1458
Old 10-20-2022, 10:24 AM
earny's Avatar
This composition of harmonious colors, light and dark with alternating sharpness and blur in my picture is somehow beautiful, isn`t it?... ;-)
The occasion not so much (still waiting for the call of my mechanic, car was in limp mode and stalling).
c16rkc (10-24-2022)
  #1459
Old 10-20-2022, 10:32 AM
RandyS's Avatar
Yes sir, I noticed the side light on your car. I like it! Sorry though the occasion was less than
thrilling. Stalling is never a good thing.
  #1460
Old 10-20-2022, 11:27 AM
mayhem's Avatar
Speaking of side lights, is there a relatively easy retrofit for US cars? I have leaper badges there and it would be neat if they acted as turn signals.
c16rkc (10-24-2022)
Quick Reply: Let's see some Sexy 308 Pictures
