Let's see some Sexy 308 Pictures
#1461
Yes, if you remove the side leaper badges, there’s a wire harness behind there that you can connect to a lamp assembly. The X300’s 95’-97’ had amber lamp assemblies there if I’m not mistaken. However, in the trunk lid of your X308, you have clear lenses there that could just snap in place on the front fender.
c16rkc (10-24-2022)
#1462
c16rkc (10-24-2022)
#1463
install an amber light behind it, I think it would look cool!.
c16rkc (10-24-2022)
#1467
#1468
Received 1,794 Likes
c16rkc (10-31-2022)
#1470
c16rkc (10-31-2022)
#1471
#1472
Interesting point was that the leading edge of the hood was clearcoat, the cracks are clearcoat, but the bigger flakes on the roof and trunk lid were failures between the initial coat of color and the second coat of color due to the depth.
c16rkc (10-31-2022)
#1474
The following 2 users liked this post by RA110623:
c16rkc (10-31-2022),
Ken Cantor (10-30-2022)
#1479
![](https://cimg8.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1124/__a82994216ec8626ffd84fc898fa18c9c8c7ffce5.jpg)
im done with iridium it doesn't last that long iridum suppose to last at least 50k miles !! my ngk burnt around 20k ! 5 spark plugs burnt supra guys with 600 hp using autolite copper i tried it it works fine if nkt better responsive at highr rpm i will never buy iridium personally i even tried denso TT bad spark plug i will stick with copper this one dirt cheap from rockauto autolite 3924
