Let's talk about the antennas!
The stock antenna on the X308 is outdated. No question about it. It looks nice and "classic" when it works (mine does BTW), but I can't help thinking about disconnecting it, and rigging up something else. Either the "invisible" one that goes on the inside of the back window, or even utilizing the leftover antenna on the ouside of the back window, that was left over from the outdated built in phone.
So I would like to hear from the people that stopped using the stock "automatic" antenna, and found a better solution. I don't want to change the appearance of the stock set up, but I really don't like the antenna going up and down every time I turn the radio on or off. It's just matter of time before it stops working, and creates a problem. Besides,....if I have the CD, tape or iPod running, why do I need the antenna out (I very seldom listen to the broadcast radio)?
Another option is to disconnect the power to it, and just listen to my music, and no radio. Sometimes though (rarely), it would be good to have the option to listen to some news or talk radio.
Anyway, ...if you found a better solution, let me hear from you.
danielsand (10-30-2012)
What gives the command to bring it down/up? Wiring the motor into a reverse ground power window switch, like most cars use would make the most sense. Otherwise relays would be needed to change the polarity that comes to the motor. Unless there are already relays in the car for that...hmmmm. Let us know what you find out about the circuit! I may want to mod mine since I practically never use the radio and the mast always seems to get broken off by some moron.
On a side note, has anyone done an antenna delete and then just ran one inside the body panels? I am doing this on my Thunderbird when it gets painted so I dont have to look at the antenna anymore/listen to the motor running.
From what I know about electricity,......the radio on/off supplies power to the antenna motor. If I interrupt this power with the switch, the antenna will not go up (obviously antenna has to be down, radio off, when the switch is turned off). Once the switch is on, and the power flows to the motor, the radio on/off button will resume it's function, and force the antenna up. When I turn the radio off, antenna will go down as normal, and the switch can be turned off, so the next time radio is turned on, antenna can't come up.
It's kinda round about way, but it will work. Question is,.....let's say radio is on, antenna is up,...what happens if the power is cut (by the switch) to the motor? Most likely nothing,...antenna stays up, turn the radio off, and the antenna stays up (no power to the motor).
I will experiment over the weekend. I would like the "hidden" antenna better, and just forget about the stock (no switches to fiddle with). I would hate to forget to bring the antenna down, and have some punks break it just for kicks.
I am glad that I am not the only one annoyed by the antenna going up and down. I can't believe that nobody modified the set up until now.
I can't believe yall don't like the antenna. It's just classy and back in the day power antennas were only on the expensive cars...when i bought my car mine was broken and i replaced it for like 9.95 plus shipping...i think it was like 15 bucks total and took 3 minutes to put in...I even had the power antenna on my 82 olds 98 replaced for 200 bucks because those units were one piece and couldnt be just replaced. Try finding a Delco original antenna for an Oldsmobile thats 30 years old lol....almost impossible. Ima keep my antenna...yall de-class your jag if ya want lol.
D. Fite (11-21-2016)
Exactly my thoughts.
It's not about "declassing" the cat, antenna stays where it is, but I want to have an option to either have it up, or down. It is WAY too tall, it makes annoying sound, and CB's are out! The thing gets all kinds of bugs and road crap on it, you need to clean it, lube it......nahh, it needs to get retired. 10 years from now, I might show it to my grandkids, and they will be amazed.
aha i remember cb antennas but my antenna on my jag doesn't make any loud noises so how can yall hear it lol. The one on my Oldsmobile is louder than the jag. I guess its all about preferences. I still like the switch idea so if you wanted the option you could raise or lower it so if you had CD player on or Ipod you didn't have to have it up.
I don't understand why your antenna does not go up.
I will need to switch on the radio unit to listen to my phone music, and by doing so, the antenna goes up.
I don't think it goes down once I select the CD or tape.
OK, Just to add my 2 cents:
I like the stock antenna, BUT, I saw one that was the "Hard Rubber" one that was only about 10" tall, maybe shorter.
Anyone seen this before?
It looks like it mounts onto the existing bracket. It stays up, but since it is so small, it really does not take away from the lines of the car.
Received 1,813 Likes
Some of you probably already saw this, but this is what I did to mine a few years back and it works very well...https://www.jaguarforums.com/forum/x...ve-one-103359/
Wow, 4 year old thread revived ... never saw that one.
