Let's talk about the antennas!
Old 11-22-2016, 01:55 AM
Stu 1986's Avatar
I like the original aerial too, it's part of the car's era. I do think it goes too high though, my old one sat a little lower than the others though. I took it apart and discovered that the top section was rusted closed but the rest of it was ok. I left it like that because I liked the lower profile.
However if you are going to remove it, greverr has the best solution and has sealed up the hole. That looks great mate, I really like that.
Old 11-22-2016, 02:38 AM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Originally Posted by greverrr
Ohh, I see you did not only loose the antenna in the omission ... I should never do it, but I think the trunk without the plinth looks very good on your car .
Old 11-24-2016, 11:03 AM
andrew lowe's Avatar
I like the subtle X308 on the bootlid/trunklid reflection!
Was that a coincidence, or a bit of photoshop???
Old 11-24-2016, 12:16 PM
omgimali's Avatar
Our cars have antennas? omission was my solution, still need to work on the phone antenna though
haha, love your youtube videos
Old 11-25-2016, 09:30 AM
greverrr's Avatar
No photoshop there 308 is generally my autoX # and I have gloss black numbers over classic circular flat black number plates giving sort of a ghost effect (I use white magnetic numbers at autoX). Trialed it experimenting between paint jobs and have left it, subtle and different, people seem to like the black ghosted look at events but my wife absolutely hates it and i'm not especially partial, just vinyl anyhow.
andrew lowe (11-26-2016)
Old 06-28-2017, 04:46 AM
papadonfamily's Avatar
Is there a relay in the circuit before the motor for the antenna?
I'm installing single DIN Pioneer which provides 300ma 12VDC only for antenna motor power.
Old 06-28-2017, 07:52 PM
Highhorse's Avatar
Received 1,797 Likes on 1,319 Posts
Its just an activation, do a site search here (highly recommend you copy the link, very useful site)... JagRepair.com - Jaguar Repair Information Resource ...search for "x308 electrical diagram" and you'll return some links. The first one "Jaguar XJ 1998" is what you want and will have a complete layout of the sound system. Yes, I could have just gotten you the direct link, but this will get you an idea of how that site works...I'm a big believer in practical application.
ericjansen (06-28-2017)
  #28
Old 07-03-2017, 07:11 AM
Einhead's Avatar
To turn on the radio and have the shiny antenna extended gracefully in front of an brand new Beamer TOTALLY owns.. :-) No one can compete.. i can almost hear the Beamer owner grinding teeths in anger of not beeing the coolest inthe hood.. hehe..
Old 08-30-2017, 12:40 PM
lamont74's Avatar
Default xj6 antenna goes up and down all the time!
My 1984 xj6 antenna has a mind of its own. It goes up and down randomly with the car off, radio off and keys in my pocket. Has anyone had this problem?
It actually kills the battery if I do not drive it for some time.
  #30
Old 08-31-2017, 10:51 AM
Highhorse's Avatar
Well, first off your in the wrong forum, this is the XJ8 one. So you may want to repost there because someone there who may know if there is an issue and a fix. But offhand I'd disconnect it at the antenna base (if that year does that there?) and meter it out. You shouldn't have power continuously going there, it should shut off when you power down. I'd be suspect of your headset.
  #31
Old 09-01-2017, 09:17 AM
lamont74's Avatar
Default Thanks
Sorry about being on the wrong forum but I figured it would be a good place since antennas were being discussed. And your suggestion was correct.....I have never had any problems with the headset but I noticed today the radio is changing stations by itself! So I think it is time for a new head unit and I am pretty sure that will take care of my power antenna problems.
  #32
Old 09-01-2017, 05:36 PM
Highhorse's Avatar
No issues amigo, its just that its probable your model may function differently than the XJ8 (the Ford years). Ford redid the electrical system, so I just want to be sure your getting knowledgeable advise.
Here, put this in your favorites... JagRepair.com - Jaguar Repair Information Resource ...you should be able to review your cars diagram at least.
  #33
Old 02-17-2019, 01:57 PM
viper1996's Avatar
Anyone running Spires or Adamesh springs without spacers?
  #34
Old 02-18-2019, 11:32 AM
kansanbrit's Avatar
Actually I have found that the antenna works OK when it is down in strong signal areas so just disconnect it and see how it works for you.
oldjaglover
04-01-2020 05:04 PM
Presence
03-13-2016 02:21 PM
philwarner
01-31-2016 09:36 AM
MattB731
09-30-2015 10:37 AM
Quick Reply: Let's talk about the antennas!
