Lighting issues - fog lights, dash lights and broken lens
1 Post
They say trouble comes in threes and this unfortunately is the case with my XJ8. ![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
I'm not sure if there are any easy solutions but I figured there's no harm in asking.
My front fog lights (rears work fine) and the backlights in the centre console (climate, defrosters etc.) do not not work. Of course this is only an issue at night but I do want them fixed.
My mechanic says a new (dimmer?) module is required to get the interior lights to work. A couple of bulbs are also burned out (clock and gas gauge) and I'll get these interior fixes done at the same time.
More worrying are my fog lights. He saying the reason why they are not working is due to an issue with the module that opperates the fog lights. Apparently this is seperate from one for the interior lights. I was wondering if anyone else has experienced something similar and if you managed to get the fog lights to work again.
To top off my lighting issues, my passenger side high beam was hit by a stone the other day and the lens shattered. The light still works and I managed to MacGyver the headlight with clear packing tape for my 600km journey home after Christmas. Let's just say it's not cosmetically very pretty but did prevent any more damage.
From searching around, it appears I have to purchase an entire headlamp. Has anyone heard otherwise and/or know if it's possible just to purchase the glass lens itself?
Thank you for your help!
The headlight lens is not itself replaceable, but you can replace the single broken lamp unit itself fairly easily. It is held in by ball-shaped pegs, pull straight out - does require a fair bit of force. Several on e-bay, and used parts suppliers on line sell them - I got one for @$100. Check your local scrap yards!
The clear plastic headlight protectors available online work very well - essentially invisible, mine have served for 4 years with no further broken lenses. PM me if you want a link to the ones I bought.
Glad to hear you're getting your car up to snuff - enjoy!
Guest
Posts: n/a
Has anyone experienced a HID "flicker" or "blue" cast with their HID lights? And, occasionally the entire light will shut off and restart? I am assuming this all means and will end up with a replacement assembly, power supply etc? Of the 3 XJ8s this is not happened before; in fact, lighting has been very reliable until.
Car has 23K on it and is garaged
Every once in awhile, the ingnitor/ballast does fail and cause a flicker, and eventually a total lamp-out. Mine flickers once every few months, and has been for 4 years. When it does die...sorry, if it ever dies, I'll find one in a salvage yard as a replacement. if your's is doing a partial burn...bluish not fully charging the lamp, yours may be on its last leg. Do a car-part.com search, or call specialized parts planet in california and ask them...they have a huge, jaguar section salvage operation.
